Does anyone know a vender that sells these for a 1981 2000.?
Already tried Vick’s and RC.
Dave
Door Hinges, Pins or Bushings?
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
Re: Door Hinges, Pins or Bushings?
Thanks Drummond,
Turned out that the hinge had cracked, and needed to be welded. However, it is strange that the hinges and bushings are not available. Maybe if one of the venders reads this, they could explain why.
Dave
Dave
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
I'm late to the party here, and it sounds like you've found a solution, but for future reference, Midwest-Bayless sells both new and used door hinges, although they're out of stock on the new ones.
https://www.midwest-bayless.com/p-6276- ... 85-u8.aspx
