What is this hose?
- Your car is a: 1982 spider 2000
What is this hose?
202000_zpsntg6wacd.jpg[/IMG][/URL]
Hey All,
Right off, forgive my ignorance. I know about a lot of things but the inner workings of my 1982 fiat spider 2000 is not one of them. So can anyone tell me what this hose is. It was leaking and I'm wondering if the gas spell I've noticed is coming from there. Can I just disconnect the hose, get a replacement at a parts store and replace myself, or do I need a special part with that specific configuration? Anything else I need to do? Thanks for your help.
Hey All,
- joelittel
Re: What is this hose?
To post a picture you have to put the image url between the img brackets, but that image has to be hosted on a photo hosting site.
The end result will look something like this.
[img]202000_zpsntg6wacd.jpg[/img]
Thanks. I actually spent about an hour trying to make that work after putting the photo on Drop Box and Photobucket. I wasn't able to move it. Any thoughts?
Forget Photobucket..... terrible problems and legacy issues here.
Try Imgur.com
Try Imgur.com
Photo bucket wasn't working for me. Hopefully this will. Thanks for the suggestion.
Hope it works this time.
- azruss
That is your brake booster hose.
No gas just vaccum
Is it okay to take it off and just replace or does that destroy the vacuum?
The vacuum only exists when the engine is running, pull and replace no problem.
Great, thanks so much for your help. Is there any reason I need to get the real fiat hose or will something comparable from any parts store be OK? Really appreciate your help. Now all I have to do is figure out where the gas smell is coming from.
As long you have tight fit. And near that hose you have input and return rubber gas line that connect to steel line.I need to get the real fiat hose or will something comparable from any parts store be OK
Use any "Vacuum" hose, made for the application. Soft rubber hose will just collapse under the vacuum.
+1 on vacuum hose for the brake booster.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Is there a trick to getting the hose off? I was able to do it fairly easily on the top but the bottom is hard to reach and I don't want to yank on it too much. And then is there a technique for getting it back on?
