rheostat dimmer 1980 spider
- Your car is a: 1980 Fiat spider 2000
Are the dimmer switches repairable???
Re: rheostat dimmer 1980 spider
Most of the ones I have opened are. There is an internal fuse in the dimmer that blows if one of the light wires is shorted to ground. The fuse is simply a small wire. Usually if you look close to the connections inside the rheostat you can see the ends of the wire. I have used one strand of a # 16 wire to replace the fuse. Usually 19 strands of smaller wire make a #16 conductor.Are the dimmer switches repairable???
I'll have to look. Thanks for the info.
I just jumpered around mine, as it was DOA. The lights aren't that bright to begin with.
Kirk
Kirk
Just repaired the dimmer rheostat . All I did was solder a strand of 16 gauge wire across the two copper lugs in the back. Works great now. Thanks again for the information.
Great! Soon you will have nothing left to do bet drive the car and wash it.
I really enjoy working on the spider. I restored it about seven years ago. Took the whole car apart and went through every nut and bolt. If I knew how to post pictures I would. It always needs something......
