My spider project just arrived from the US (to UK) and I'm embarking in the project.
I bought cheap because I wanted a project. The car is very rust free (which is why I bought it) and it runs and stops. I only gave $2250 for it so I think that's good. Can't get anything other than a project in the UK for double that.
First issue is the drivers door. The car's had a new hood and it looks to be fitted ok and even all around, but the drivers door quarter light frame hits the roof hardware at the front so it won't close with the roof latched up
The passenger side is good and the sill to roof measurements are the same on both sides so it seems to be the door.
You can probably see the lousy fit and large gap - yes the door frame where the hinge bolts is cracked which is probably causing this, but the door height seems good so I can't see that fixing the crack (which I will) will particularly solve the quarter light issue.
Any ideas ?
thanks
Lee
