77 Fuse G keeps blowing
- Your car is a: 1977 124 Spider
This is the fuse that powers the Instrument panel, Front left parking Light & rear right tail light. I've disconnected parking light & side marker and right rear tail light with side marker but fuse continues to blow when switch is put into middle (parking postion), Any help appreciated!
Re: 77 Fuse G keeps blowing
Checking the wire diagram fuse 6 there are 2 yellow/black wires attached to the bottom terminals of the fuse. Pull off one at a time and see what happens. Most likely the fuse blowing is associated with one of the wires not both. Once you have isolated it to which wire you need to see what circuits from fuse 6 work and which do not work. Hope this helps
