reverse/back up lights
Fiat gurus, there's just one small step before I can get this salvaged Spider back on the road. At the connector I'm reading 45ohms. I'm wonderin if I need to replace the switch?? Sure would make my life easier...she needs a brake and lamp certification and then an emissions test to get the plates back, so all the lights need to work.
Re: reverse/back up lights
If you are reading the reverse switch resistance at the back of the transmission that is too high. The switch or the wires are bad.
a new switch is on the way, see how that plays out...this is the last obstacle to traverse before completing the reg. with the dmv
- azruss
lamp sockets and associated grounds may require cleaning to get all the lights working right.
Guess we'll find out on Thursday...plus the tail-light assemblies are brand new...wiring is groovy...just a bad switch I guess...
