'74 ignition switch rebuild
- Your car is a: 1974 124 sport
attempting to rebuild my ignition switch via mirafiori instructions. switch has extra contacts in the center that prevent installing white plastic "ramping disc" w/ screws. not the best explanation, but has anyone out there rebuilt the switch in a '74 sport? could use a heads up. thanx.
if you can't be an example, be a warning.
Re: '74 ignition switch rebuild
disregard previous post. w/a '74 ignition switch , the reassembly procedure steps differ in order. but it's still a major help. got my switch working again.
