Since recently joining the group and from reading elsewhere, I notice that many of the electrical issues point to poor and inadequate earthing. This is more so, if you have the battery in the rear of the vehicle (boot in Australia, trunk in the US). Fiat, in their wisdom, decided that only the positive lead needed to come forward, with the negative earth relying solely on the body for conduction. This has to take into account the panel joins, grease, paint, etc.
In my beast, I purchased some welding cable and ran the negative lead with the positive to the front, grounding it on the body and, in my case the engine at the oil filter mounting nuts. This coupled with start washers at all grounding points, has made for good lighting, a gutsy starter motor and wipers.
It is not a difficult job, with a couple of holes having to be made front and back. Oh, I did retain the body ground at the battery box.
Cheers from Australia,
John
1977 Spyder 1800cc with twin 40 IDF Webers.
Good Earthing
- Your car is a: 1977 124 Spider
Good Earthing
John in Oz
First Fiat: 1970 124 sedan 1970 - 1976
Then horse float towing vehicles up to present.
Current Fiat: 1977 124 Spider 1756cc with twin Weber 40 IDF's
1970 124BC coupe; 1756cc with twin Weber 40 IDF's, used for sprinting
- Odoyle
Re: Good Earthing
Very cool! Could you post some photos of your set-upjandarah wrote:Since recently joining the group and from reading elsewhere, I notice that many of the electrical issues point to poor and inadequate earthing. This is more so, if you have the battery in the rear of the vehicle (boot in Australia, trunk in the US). Fiat, in their wisdom, decided that only the positive lead needed to come forward, with the negative earth relying solely on the body for conduction. This has to take into account the panel joins, grease, paint, etc.
John
Re: Good Earthing
As far as the negative cable, there is not much too see, but I will try. I have also installed a battery switch up front to isolate the battery. It is annoying th have to pull off the rear battery box to disconnect the battery, when doing work up front. I think that it is meant for marine applications, so it is heavy duty. I will try a get a photo.
Enjoy your Spyders,
John in Oz
1977 1800cc with twin 40IDF Webers.
Enjoy your Spyders,
John in Oz
John in Oz
