Well, I have a 1981 fiat spider fuel injected, and it is a headache, my car was good, but then back to home my car start having aceleration problems, when the car is in idle all good, but when the car start moving, it jumps and its imposible to drive , when i check the spark plugs, the four are all black , I check everything, check distributor, new coil, injectors all good, new spark plugs, new lambda sensor (oxygen sensor), check all the sensors with ohmnimeter with help of the maintenance manual and all was good, I don't know if the ecu is damaged, I need help!
