Got them on my 78timspider wrote:good stuff- question: do I have a gang of grounds like that on my 78 as stock? I haven't seen it in my tinkering. I'm about to tackle an ignition wiring problem and this sounds like it would be a good thing to add to that process.
thanks for always posting great stuff
Why not dielectric?divace73 wrote:also use conductive grease (not dialeteric) everywhere between the electrical contacts.
Dielectric grease is non conductive, as an example it would be used from spark plug shaft to rubber boot to prevent sticking and protection, it shouldn't be used on conductive surfaces.TimpanogosSlim wrote:Why not dielectric?divace73 wrote:also use conductive grease (not dialeteric) everywhere between the electrical contacts.
The grease is there to protect the metal from the elements. The electrical connection remains where you have direct metal to metal contact.
"conductive" grease (like copper anti-seize) is just dielectric grease with metal flakes in it.
Dielectric grease is non-conductive so that it can be used inside multi-contact electrical connections without causing current bleed/short circuits between the contacts. That is why it is packed by the manufacturer inside light bulb sockets, computer connections, firewall pass through gang connections and such. In a spark plug boot it won't short out the ignition if it weeps down the side of the plug to the head or wicks up to the jacket of the lead. Non-conductive grease is also used for the bearings and connections in electric motors to prevent the fields and commutators from getting shorted out however many motors with grease fittings end up unfortunately topped off with a conductive grease during servicing to die an early death.divace73 wrote:Dielectric grease is non conductive, as an example it would be used from spark plug shaft to rubber boot to prevent sticking and protection, it shouldn't be used on conductive surfaces.TimpanogosSlim wrote:Why not dielectric?divace73 wrote:also use conductive grease (not dialeteric) everywhere between the electrical contacts.
As you say the metal flakes make it conductive.
My 78 has one ground star on the right front fender close to the front and another ground star inside the dash above the ignition switch so possibly I have a later 78.timspider wrote:I don't have the consolidated grounds on my early 78, so I'll hunt them down individually.
that back and forth about dielectric grease was pretty informative- thanks
