1971 Spider ignition switch question
I found the Mirafiori article regarding rebuilding the switch which I may or may not need. My problem is the pink wire that bypasses the electrical block and goes towards the key cylinder is the one that has visibly fried insulation. Has anyone disassembled the switch to the level where that wire can be swapped? If so how? Id like to re-use the switch as I don't think it has any other issues...
Re: 1971 Spider ignition switch question
Are you asking if the electrical part of the switch can be swapped? Yes, easily, it is held in by a wire ring.
No, I got that part out, the wire that runs past it down to the key area is the one I want to swap but I don't know how to dismantle the switch any further...
I never took that out. That is for the 'key in the ignition' light.
- divace73
I use that switch for my radio (all the seat belt function has been disconnected), so I can have my radio on when I put my key in and not the ign on.vandor wrote:I never took that out. That is for the 'key in the ignition' light.
Cheers David
see my >>You tube channel<<
Great idea!!!
I have always wanted a push button ignition. Can one be installed and has anybody done it?
Gene
North Carolina
Gene
North Carolina
Gene
North Carolina
North Carolina
Can i just abandon the 2 wires and not re connect them?
Yes you can leave the 2 wires disconnected. The only thing that will not work (if it was) is the key in ignition warning chime.
- divace73
someone here has done it, It's easy enough, basically replicate the turn part of the ignition with a push button.brackie1 wrote:I have always wanted a push button ignition. Can one be installed and has anybody done it?
Gene
North Carolina
http://www.jaycar.com.au/Electromechani ... h/p/SP0773
Having a separate start button has always puzzled me, they went from that in the 'olden days' to a convenient turn of the key and now every body want to go back?? Each to their on I guess
I have seen somebody put it in place where the cigar lighter spot is.
Cheers David
My '53 Studebaker Commander had the push button under the clutch pedal, so to start, you'd just push the clutch to the floor. In addition, it acted as a neutral safety switch,...
Todd.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
- azruss
Here we are back to owner modified electrics. How many of us complain about PO modifications. Before moving to a push button start, take pity on the future owner of your car. The only reason the modern car as gone this direction is cost.
Neat!wetminkey wrote:My '53 Studebaker Commander had the push button under the clutch pedal, ...
My friend has a '59 Buick and to operate the starter one has to step on the gas! Crazy.
