Engine starts, but wont stay running.
DavidProps
Your car is a: 1973 124 Sport
Post by DavidProps »
Hi There,
I've just picked up an '80 spider.
The PO said it ran fine until he started it with the tail lights disconnected. Now it takes a few tries to get it started and it only runs for a few seconds, then dies.
I'm not sure if it is an electrical issue or a fuel delivery issue. Any thoughts?
It might be helpful to note that when the key is turned, the oil light does not come on.
David
'73 124 Sport
'80 2000 Spider x 2
'85 VW Single Cab Transporter
'59 Lambretta S2 Li150
76was124
Patron 2019
Patron 2019
Re: Engine starts, but wont stay running.
Post by 76was124 »
Sounds like it firing up on the cold start injector, but is not getting any fuel from the normal injectors. What's the history on this car? Did it run alright recently. Or not since......what?
I would check to see if the grounds for the injectors are properly connected. There should be two wires grounded on a bolt on the intake manifold close to the firewall, driver side.
Current 81 Spider 2000
Previous 76 Spider
DavidProps
Thanks for the info.
I'll check it out.
I don't know the history on the car. I pick it up on Tuesday. I'll ask the PO then for the full story on the fault.
David
'73 124 Sport
'80 2000 Spider x 2
the fuel pump ground is at the left taillight
narfire
Post by narfire »
When the ignition is on, not to worry too much about the light at the moment, might be burned out.... (check oil level eh...)
Anyway access the AFM by taking the air cleaner off. Turn the ignition on and push the flap in the AFM. Have a helper put their ear to the fuel pump and have a listen. Should turn on. When cranking the flap opens and the pump should turn on.
OK pump is running, when was the last time the fuel filter was swapped out?
Disconnect the fuel line at the cold start injector at the front of the intake plenum. Crank and you should have fuel around 30+- psi there. (spray into a can). OK have fuel delivered, then are the injectors working? As mentioned there are two grounds for the injectors grounded out to the bolts holding down the top of the intake plenum.
Spark? pull plug lead and ground to the head.....
All the air hoses free of cracks and clamps snugged down? Might be un-metered air entering the intake after the AFM ?
Where are you purchasing the spider? Decent car show in N. Van on fathers day at the park next to the marine training center.
Chris
Is this car Fuel injected or Carburetor??
76was124
Patron 2019
Patron 2019
Post by 76was124 »
So Cal Mark wrote:the fuel pump ground is at the left taillight
Ditto what Mark said, check that the fuel pump ground wire is properly grounded. I moved mine to bear metal in the trunk vs the original location under ther long thumb screw on the driver's side tail light.
Previous 76 Spider
DavidProps
Thanks again for the advice.
I'm looking froward to getting it going.
I've had a '73 Spider for 10+ years, this is my first experience with fuel injection.
I'm getting the vehicle in New Westminster.
I've been to the Car Show in North Van many times. It's always a fine day out.
I'll let you know how it works out on Tuesday.
David
'73 124 Sport
'80 2000 Spider x 2
DavidProps
I tried all of the above, but what seemed to work was swapping out the AFM and spraying contact cleaner into all of the connectors.
There is still an issue with getting it to turn over. I suspect it is the ignition switch. If I hold the wires coming out of the switch in a certain way, I get nothing, another and it goes "click". Next chance I get I'll have a look at the starter connections...
My '73 just developed the same problem, first time in 10 years it hasn't fired right up. Alas.
Till next weekend...
David
'73 124 Sport
'80 2000 Spider x 2
