Fuel gauge defect?
LucN
Your car is a: Fiat Spider Pininfarina 1979
Fuel gauge defect?
Post by LucN »
Hi,
Today i measured between the two connectors of the fuel tank 125 ohm, on the fuel gauge i mesasure 127 ohm, the fuel gauge shows an empty tank, while its neerly full.
If i remove one of the wires from the connectors, nothing happens.
Does this means, the fuel gauge is defect?
thx for your response
Luc
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Re: Fuel gauge defect?
Post by RoyBatty »
Are the wires reversed?
On my 1981 Spider if I disconnect the light blue wire from the sender the gauge reads empty with the ignition key on.
Grounding the light blue wire with the key on makes the gauge peg.
It is very common for the fuel tanks to rust where they meet the trunk floor and loose their ground. I add a ground wire under one of the sender nuts to a good ground. This cures lots of gas gauge problems.
LucN
Post by LucN »
Hi
even if I reverse the wires, nothing happens (the gauge still shows empty....)
are there a few easy steps to follow to ditermine, the sender or the gauge is defect?
Luc
azruss
Post by azruss »
neither wire are a ground. The ground is thru the gas tank studs. one wire is the gauge the other is the idiot light.
LucN
Post by LucN »
is it correct (as a test) that if one of the tank wires is on the ground, the idiot lamp should work?
Luc
I believe grounding one of the wires will lite the idiot light and grounding the other should make the gauge needle peg beyond full. Do not leave the gauge pegged too long or you could damage the gauge.
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
It's usually the fuel level sending unit. It's almost never the gauge.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
LucN
Post by LucN »
i did some tests today,.....
grounding one (or both) of the tank connection give no response of the gauge
maybe its best to replace both sending unit and gauge?
grtz,
Luc
I think you need to inspect the back of the fuel gauge. There needs to be power (12V) from the fuse panel for the gauge and idiot light to work. On my 1981 the gauge has a connector maybe it has become disconnected.
LucN
Post by LucN »
Hi,
yesterday, I've replaced the sending unit, the gauge still points empty while the tank is nearley full.
I've replaced the gauge with a used one I've bought last week, the result is identical
fuse = ok,
all sugestions are appreciated to solve this mystery
Luc
DieselSpider
Post by DieselSpider »
LucN wrote:Hi,
fuse = ok,
Luc
When you replaced the gauge did you first verify that it was good and then once installed that there was power going to it using a meter or a test light. This would be the first test. Next you can test the gauge as installed by connecting momentarily the other connectors on the back of the gauge to the ground and then on one the idiot light should light while the other will peg the gauge indicating a good gauge. You can bench test the old gauge this way too and you can also test the old gauge and sender by hooking them up outside the car. Next connect the two wires from the sender together and with a meter read continuity between the gauge ends of the wires and if none then one of the wires is broken somewhere so each one needs to be checked individually by connecting one end to ground and then checking continuity to ground on the other end.
