I need to confirm two things, is the steering assembly on my Spider the correct one - i.e. original for at 1981 F.I. Spider - there are two connectors on the assembly for the horn connectivity.( grey/black and purple/black wires )
Secondly is the steering boss the correct/original boss, the assembly has two connectors, however the boss has only one connection ring, - and one wire running down from the center from the horn button, all earthed therefore the horn in always "ON" and very noisy when I reassemble everything correctly.
Any ideas or suggestions ?
I've checked voltage and continuity through the circuits. I know where the bypass for the second button is connected in.
