Maybe I'm lazy asking is free...
Where is the C18-connector?
Do I have to remove the steerigg wheel cover to find it or is it somewhere deeper (more near the pedals)?
FI 2000 1982
C18 connector
- Your car is a: Spider 2000 1982
C18 connector
Spider 2000, 1982
Ex Jaguar X-type 2.2, 2009
Jaguar XE 2.0 AWD
"A single fact can spoil a good argument"
Jaguar XE 2.0 AWD
Re: C18 connector
I believe C18 has 12 pins or contacts in it. The 12 contacts are in a single row. For a left side driven car it is located between the steering column and the left side of the car. Near the hood release. The wires exit the base of the steering column.
Re: C18 connector
Thank you.
Now my rear light are as bright as they should be.
All connectors are cleaned with dremel and some electrical grease has been added to the connectors.
Somewhere at this board were discussion about electrcal greases, so here is my way to do it.
I add Gulf electrcal grease in places which have a possibility to get wet (like rear lamps) or some other way to get moisture.
The grease is same what I used in my past (>25y ago) at tram workshop.
Main idea is that you have to put really thin layer of grease.
Also the grease is used when you have really big fuses or you connect diffrent metals together (like Cu-Al).
Spider 2000, 1982
Jaguar XE 2.0 AWD
Jaguar XE 2.0 AWD
- bradartigue
Re: C18 connector
Find all of the Cu/Al connection points in a FIAT and you'll add 60 pounds of weight to the car in grease.nalle wrote:Thank you.
1970 124 Spider
http://www.artigue.com/fiat
Re: C18 connector
I'm not going to fill all connectors (cu-Al) with grease, but if I found oxide then I'll use it (after cleaning).
I still have the same tube of grease than 25 years ago (57g).
You don not have to fill the whole car with the grase, when you use it (60 pounds).
But if you like to do so, then you may do it.
Spider 2000, 1982
Jaguar XE 2.0 AWD
Jaguar XE 2.0 AWD
Re: C18 connector
A little smear or dab will do you so an 8 ounce tube should be plenty.bradartigue wrote:Find all of the Cu/Al connection points in a FIAT and you'll add 60 pounds of weight to the car in grease.nalle wrote:Thank you.
