Slow blinkers
paintdudeluke
Slow blinkers
Post by paintdudeluke »
Is is normal for LED front blinkers to slow down flasher function? The dash indicator (blinker) not doing much, maybe one flash. Do I need to add current draw to the light to make it work normal?
Re: Slow blinkers
I believe the stock flasher in a Fiat is current dependent. Installing bulbs or LED's that operate at a different current than those specified in the owners manual will change the flash speed.
LED's draw way less current than the original incandescent bulbs.
There are flashers that are not current dependent and have adjustable flash rates. Many of the LED vendors offer them.
If you want to use LED's you might want to upgrade your flasher.
I am not sure but I think you need a 3 prong flasher. The third prong lights the dash indicator when the signals are off.
This might work http://www.ebay.com/itm/LED-Relay-Flash ... 88&vxp=mtr
I bet more than one of our Fiat vendors also carries them
toplessexpat
Your car is a: 1976 Spider 1800
Re: Slow blinkers
Post by toplessexpat »
Yes, installing LED blinkers on the front will slow down the flash rate...
Autoricambi sell an electronic one that will work:
http://www.autoricambi.us/product/EL4-0 ... lectronic/
Many classic Fiats - it's a disease!
www.mirafiori.com
paintdudeluke
Re: Slow blinkers
actually a new one from oreileys for $4 fixed it. The indicator was just a crappy connect on the gauge.
toplessexpat
Re: Slow blinkers
Try adding rear LEDs :)
www.mirafiori.com
