IDF 40 aircleaner options
- TulsaSpider
Hi all! I need your help shopping. I installed IDF 40's last year that came off a 68 Coupe. The lunchbox style air filers are rusted and tired. Please post pics of different options, pro's and cons etc. The engine is a 2L block 1800 head HC pistons medium cam. Thanks
- Your car is a: 1975 Spider
Re: IDF 40 aircleaner options
i am playing on a plasma table right now, i will make a prototype filter assembly which will be a open type that will use a larger oval filter that will encompass both carbs. stay tuned...
son has 78 spider
son has 78 spider
You should have a ready market for such an item. The OE "turtleback" dual-snorkel unit is very rare.
You probably already know that there's not a lot of height to work with.
- TulsaSpider
Yes I was quite relieved when my hood shut when I installed them!!!
I have the chrome lunchbox style in stock for the IDF carbs
- Redline
- Your car is a: formerly a 1971 Fiat 124 BC Coupe
http://www.124bc.com
- TulsaSpider
That's pretty fricking wicked!
I guess I'm leaning towards the little stacks or the two turtle back looking ones....
that is exactly the concept i was thinking of myself.
son has 78 spider
son has 78 spider
as for stacks, the stacks must have a turned over lip at the top , trumpet style and there has to be enough clearance between the top of the trumpet to the air cleaner cover, that is the math and theory and such , i am still working on. the only issues are the hood clearance and filter area.
son has 78 spider
son has 78 spider
- Redline
I went from this:
To this:
With these:
Sounds nice, but probably not to everyone's taste. You need to run a separate breather filter, and we can debate filtering efficiency all day. I only do 3'000 km a year in clean conditions and plan a rebuild sometime in the next years. When I do, I'll probably move to a custom setup like the one I linked, with a nice ribbed finish and crackle paint.
To this:
With these:
This is the custom cold air box on the coupe. Air is drawn from in front of the radiator - outside the engine bay - through a radiused 3" bell, and drawn through an enclosed K&N filter, straight to the middle of the carbs, 3" all the way. Under the top are radiused horns for the 44 IDFs. No bends, totally cold air, and really quiets down the carbs and makes them sound great from inside the cabin (less of a growl - more of a whoosh)
http://farm9.staticflickr.com/8523/8670 ... afffe9.jpg
- TulsaSpider
- TulsaSpider
Can you tell me what that is? Pics?
- Redline
Google's your friend.
Several images of the ITG:
https://www.google.com/search?q=itg+air ... 40&bih=780
e.g.
e.g.
