connector name and where to buy them
mighty7
Your car is a: 1985 Pininfarina Spider Azzura
Post by mighty7 »
Does anyone know what these style connectors are called and where I can buy them? I have stumbled across them in the past but can't seem to find them online again.
Thanks, Scott
Re: connector name and where to buy them
that isn't a connector, it's an insulator for the spade connectors that are inside
mighty7
Post by mighty7 »
Still can't find them online. Do you know how to get them or what they are called online to get a google search to reveal them?
Can't help you with where to purchase the spade connector protective sleeves. I would call our Fiat Supply Vendors for assistance.
Modern spade connectors are available in most auto part stores and electrical supply houses that are insulated and do not require the protective sleeve in the photo.
If you existing spade connectors are ok you could pull them apart slip a 3 inch section of insulating sleeve over the the wire, remake the connection slide the sleeve over the spades and ty-wrap the sleeve on both ends so it can't slip off the spades.
mighty7
Post by mighty7 »
Here is an Italian company that still has them in their catalog. Just got to figure out a way to get one.
http://www.meccanocar.it/c/document_lib ... upId=11052
mighty7
Post by mighty7 »
