My 1981 Spider ran just fine when I parked it in the garage last night. Today, in the morning it did not start.
Motor was turning easy and I tried a different (known for working) ignition switch. No change so back to the original switch.
Than I pulled a plug and did not get a spark. Next I pulled the wire coming from the coil and and during starting the car I got three single, random sparks and than nothing anymore.
I checked the resistance on the coil both ways and it was within specs.
I checked the voltage on the +B terminal and it was a little over 12 volts so within specs.
Then I tried the resistance ground check from the coil ground to the battery ground but how am I going to do that when the battery is back in the trunk. So I checked from the cylinder head to different ground spots by the coil and they where all in the 2 ohm area.
Than I measured close to six k ohm from one end to the other on the wire in between the coil and the cap and close to 4 k ohm on the wire feeding the first cylinder so I hope that is enough proof for the wire to be in working condition.
I do have another coil I could try but does it make sense. I have all kinds of spares from working car that I slaughtered but don't know where to start.
My fuel pump gets power when I turn on the ignition and it has been that way as long as I owned the car.
Is there anything I overlooked or anything else I can try?
No spark from coil?
Re: No spark from coil?
Check the ignition module which is located underneath the coil assembly. You can remove it and Autozone can check it.
Thank you Harmon 30, I just replaced the ignition module with another one and it did not do it.
Since that did not work I had to replace the coil and that was not the problem either.
After that I replaced the wire from the coil to the cap and that did not make it spark.
Now the battery is on the charger
Any other thoughts?
Any other thoughts?
- divace73
make sure the while cable for the dizzy is intact, they can also fray inside the dizzy.
Cheers David
see my >>You tube channel<<
Called the pickup coil. It's the most common cause of ignition problems in late Spiders.divace73 wrote:make sure the while cable for the dizzy is intact, they can also fray inside the dizzy.
Re: No spark from coil? "SOLVED"
vandor wrote:Called the pickup coil. It's the most common cause of ignition problems in late Spiders.divace73 wrote:make sure the while cable for the dizzy is intact, they can also fray inside the dizzy.
And now I know and will always remember to look there first.
Thank you Divace and Vandor.
All these years and last night the wire decided to get to snugly with the header
