Trying to figure out how to hook up my tachometer as it was not hooked up when I got the car. Buddy said "you could just hook it back up" so it makes me think that it is a pretty simple fix.
From everything I can see in my wiring diagrams, it looks like I am just missing having the brown tach wire hooked up to the coil. There is a loose unattached wire right by the coil so I assume that is the right one. All the wires are hooked up behind the dash, and other than one loose black and white wire at the fuse box, everything else seems to be hooked up. Do I simply attached the brown wire to the coil and I am good to go? Which terminal, positive or negative? Doesn't appear to be any additional hook ups so I guess it will just piggyback on the correct terminal.
Bonus points if you can help me identify the black and white wire. I don't seem to have instrument panel lighting. Is this all I need for that as well?
Tachometer Hook-up
- seabeelt
- Patron 2019
Re: Tachometer Hook-up
What year car. Hard to tell from just the description
Sorry, 1974 Spider.seabeelt wrote:What year car. Hard to tell from just the description
As far as the black and white wire goes, it appears there is two empty spots on the fuse box. From what I can tell 5 and 6.
I went ahead and tried to hook up the brown wire to the negative side of the coil. The car would then not start. I decided to take it off and she started right up. Either that was a coincidence or was part of the problem. Debating on whether or not I should try the positive side but am worried that I will damage some wiring in the process.
Any one have any suggestions?
Tac wire goes to the positive side. But some one will verify that before u attemptjclarkey wrote:I went ahead and tried to hook up the brown wire to the negative side of the coil. The car would then not start. I decided to take it off and she started right up. Either that was a coincidence or was part of the problem. Debating on whether or not I should try the positive side but am worried that I will damage some wiring in the process.
I'm no mechanic,just a masonry man
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
TACH DO NOT GO TO POSITIVE ON COIL !!!fiat218 wrote:Tac wire goes to the positive side. But some one will verify that before u attemptjclarkey wrote:I went ahead and tried to hook up the brown wire to the negative side of the coil. The car would then not start. I decided to take it off and she started right up. Either that was a coincidence or was part of the problem. Debating on whether or not I should try the positive side but am worried that I will damage some wiring in the process.
Any one have any suggestions?![]()
Tach signal comes from the negative blade of the coil.
Wire should be brown, but you need to check with an ohmmeter if this brown wire at the coil does go to your tach.
Good luck.
Whew, good thing u saidwesty64 wrote:TACH DO NOT GO TO POSITIVE ON COIL !!!fiat218 wrote:Tac wire goes to the positive side. But some one will verify that before u attemptjclarkey wrote:I went ahead and tried to hook up the brown wire to the negative side of the coil. The car would then not start. I decided to take it off and she started right up. Either that was a coincidence or was part of the problem. Debating on whether or not I should try the positive side but am worried that I will damage some wiring in the process.
Good luck.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
So I hooked it up again to the negative and once again the car would not start. This was after a nice drive as well. Took the wire off and she started right up. Any ideas on what the heck is going on?
Good luck.
Maybe that not the tac wire, just saying
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
you're probably right.fiat218 wrote:Maybe that not the tac wire, just saying
did you check if this brown wire goes to the tachometer in the dash ?jclarkey wrote:So I hooked it up again to the negative and once again the car would not start. This was after a nice drive as well. Took the wire off and she started right up. Any ideas on what the heck is going on?
Good luck.
