The issue was the pump would not turn with voltage applied.....
Here is why
The external conditions of the motor are that of a rust encrusted find from the bottom of the ocean.
After removing the two rivets holding the motor to the impellor housing and removing the three tiny screws seen here
You can see that the inside of the motor housing and electricals were worse than the outside.
So we take some 400 grit sandpaper and attack the inside of the magnet and the outside of the windings to remove the rust.
Apply a little grease down in that tiny hole at thebottom of the housing
And check the tiny brushes (sorry for the poor photo)
and reassemble - (mind the plastic motor seperator between the impellor and motor has a key that fits the metal housing)
And test... Voila she runs nicely. Now all that is left to do is reinstall the tiny screws and find some replacement screws for the rivets to the impellor housing.
r/
