Under-dash Panel
profcucchi
Your car is a: 1979 Fiat 2000
Under-dash Panel
Post by profcucchi »
Looks like when the interior was redone the owner didn't replace a panel under the dash on the passenger side. Presently, it's all open with carpet and pad showing.
Can anyone give me an actual name for this part?
Thanks.
1979 Fiat 2000 "Luigi"
FiatBen
Re: Under-dash Panel
Post by FiatBen »
I'm not sure what you are referring to. Could you post a pic? And what year is the car? That will help a bunch.
124JOE
Post by 124JOE »
I think thats the upper counsle it holds the radio,hazzards,cig lighter and the cabin light
FiatBen
Post by FiatBen »
That was my first guess until I reread that it was in the passenger compartment.
maytag
Post by maytag »
well, as far as I know, the console that holds the cig lighter, radio, etc etc, IS IN THE PASSENGER COMPARTMENT! :lol:
But it sounds to me like he's describing the kick panel on the right side of the car.
but pics would be worth a thousand words right now.
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Post by dmwhiteoak »
Kick panel on passenger side inside passenger compartment. That's my take.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
divace73
Post by divace73 »
what about that panel that the all the relays and stuff is on?? Mine was missing when the PO converted to RHD, I didn't even know it existed till I read it in a fiat spider electircal book.
Cheers David
see my >>You tube channel<<
maytag
Post by maytag »
divace73 wrote:what about that panel that the all the relays and stuff is on?? Mine was missing when the PO converted to RHD, I didn't even know it existed till I read it in a fiat spider electircal book.
I don't know how that panel being absent would result in carpet and pad now improperly showing......
profcucchi
Here is a picture of the passenger side under the dash.
Is something missing?
divace73
Post by divace73 »
that looks a lot better than what mine did, that is the plate I was referring to, is that not normal?
Cheers David
profcucchi
divace73 wrote:that looks a lot better than what mine did, that is the plate I was referring to, is that not normal?
I hope not! that looks awful. Is there an aftermarket to fix this?
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
That's what mine looks like, can you see it without sticking your head under the dash?
Trey
profcucchi
htchevyii wrote:That's what mine looks like, can you see it without sticking your head under the dash?
Thankfully, I can't see it if I'm not under the dash. but knowing its there bothers me.
At least I'll try to tack up the pad.
manoa matt
Post by manoa matt »
There should be a metal tab that holds the underlayment/insulation up in position. That carpet appears non original and looks to be cut short. The metal panel screwed up under the dash is original, it houses relays and switches, however it does appear to be bent. The black plastic box in the right of the picture is the windshield delay switch and should be attached to the metal panel.
