Who rebuilds transmissions?
- maytag
Hey y'all:
so.... I installed a used trans, with unknown provenance, because i knew mine was bad.
this one ain't great.
I can keep buying $100 transmissions.....
but I;d really rather have a good on in it.
Who have y'all used, that does a good job, but won't kill the bank?
Re: Who rebuilds transmissions?
Maytag, you should be able to accomplish this with the help of a manual. The books lay it out step-by-step with pics
- maytag
o I'm sure I could..... but it's all about TIME these days.So Cal Mark wrote:Maytag, you should be able to accomplish this with the help of a manual. The books lay it out step-by-step with pics
but thanks for the idea, and the vote of confidence.
Is there such a thing as a 'kit' that I could have on hand? or is this a "tear it apart, mic it all out, order the parts I need to replace" sort of project?
- ga.spyder
I know Jon Logan of Midwest 124 has rebuilt quite a few of them,with excellent feedback.I have no idea on cost.
Craig Nelson
Fling It Around Turns !
Any shop can do itmaytag wrote:Hey y'all:
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Most transmissions you can buy a kit, comes with brgs and seals, I would bet you can for our fiats too.
Simple trans you will have no issues.
Unless you try to put relays in it
Keith
Keith
- maytag
majicwrench wrote:Most transmissions you can buy a kit, comes with brgs and seals, I would bet you can for our fiats too.
Keith
SUNNUVA!!!
I did mine and order that kit http://www.ebay.com/itm/Fiat-124-Coupe- ... dc&vxp=mtr.
You will also need a gasket set and you can change the synchro.
- 81SPIDERMATT
holy crap that is funnymajicwrench wrote:Most transmissions you can buy a kit, comes with brgs and seals, I would bet you can for our fiats too.
Keith
i keep up on most threads...... comment on very few.... but.... that is funny
- blurple124
This is a topic I am interested in, because it sounds as if I will be in a similar situation....within the next 5 years
I like to study up, you know! Sure, Maytag might be able to rebuild a transmission, but what about someone who isn't as familiar with relays
Better to get a rebuilt transmission from a place like Bayless, or to buy this kit and go for it? I have an input shaft bearing on it's way to failure.
Charlie
1997 Jeep Wrangler TJ Sport
- giuliot60
- Your car is a: 81 Fiat Turbo removed Spider
Mine make a little noise when the my foot's off the clutch and in neutral. Is that all you need to change are the bearings, synchro, and gaskets? How much do the last 2 cost?
Giulio/Charlotte
Actually the bearings are very often reusable, if I was on a budget those would be the last thing I'd change, unless one was bad.ORFORD2004 wrote:I did mine and order that kit http://www.ebay.com/itm/Fiat-124-Coupe- ... dc&vxp=mtr.
I always replace all the synchro rings on 1-4 and the springs under them, as those can break. Unless they look perfect I replace the synchro sleeves and the shift forks. Gears may need replacing, they each need to be inspected.
Or you can replace every bearing, synchros, sleeve, and shiftfork, and have basically a new transmission.
Any competent shop can do the work. Jon Logan does great work, and I have probably over 40 transmission under my belt.
New one is about 1600 ?vandor wrote:Actually the bearings are very often reusable, if I was on a budget those would be the last thing I'd change, unless one was bad.ORFORD2004 wrote:I did mine and order that kit http://www.ebay.com/itm/Fiat-124-Coupe- ... dc&vxp=mtr.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1975 Spider
i will build a fiat transmission for 85.00. 75.00 to me and 10.00 to this site for every one built. you pay the site owner yourself that way you are assured that this great place gets its just deserves.
you can supply the parts or i will... your choice... i will quote first after tear down
you pay shipping to and from. i will send it by your choice of carrier
son has 78 spider
son has 78 spider
Guiliot,
All you really need to do is change the bad parts. If it is making noise, it has a bad bearing. WHen aparts, spin/inspect the bearings. Change bad ones. I often change all of em, if one has failed it has been spreading metal dust thru everything.
If it shifts fine, synchros and shift forks are OK. If it grinds into gear or pops out, you have parts to change.
Keith
Keith
