relay locations
relay locations
Hey all, almost completed tearing apart 72 fiat 124-- when changing out the dash I found 4 buried relays..which is a good thing. Would any one have a list of ALL the locations with part numbers ? For me it's easier just to replace with new. Ive only found diagrams from 1976 on THANKS
jlwhite1081@yahoo.com
- Your car is a: 1976 124CS1 Spider
Re: relay locations
Try this resource for wiring diagrams, no part numbers but very detailed and you can get the part numbers more easily once you know what the part is called or does.
http://www.artigue.com/wiring-diagrams/
mP
mP
Re: relay locations
Taking the dash out of a '71 soon....wires will all still be in place. Would pictures help you? If so, PM me an email address.
Re: relay locations
Re: relay locations
Ive located 4 relays under my dash--2 by the stering column and 2 under the glove box. If you can help with identifying and part numbers that would be great. During my resto its easier just to replace with new and check all conections with grounds than to trouble shoot. If I buy alittle at a time its not so hurt-ful in the pocket... THANKS
