side mirror
fiat218
side mirror
Post by fiat218 »
i have a 80 2000
apparently there was no outside mounted mirror, there no indication that there was any ,there was nothing showing on the inside door card other then a hole in which i am sure that was for the adjustment cable etc
so where was this mirror mounted?
any one have a photo
thanks
PS. i am learning to spell :P
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
ga.spyder
Re: side mirror
Post by ga.spyder »
Jim..its like someone else typed it for you!! :lol: Just kidding.My82 doesnt have a pass. side mirror either.I have purchased or been given several mirrors off late models,and none are a match.I will find the right one eventually.
Craig Nelson
Fling It Around Turns !
rlux4
Patron 2022
Patron 2022
Re: side mirror
Post by rlux4 »
Are you talking about the driver's side? I've never heard of not having a mirror there. If that's the case someone has taken it off and welded the mounting holes I'm sure. You'd be able to see this by taking off the door panel and looking at the inside of the door skin, just aft of the vent window. Replacement mirrors for the driver's side are available, if you put one on just be sure to set it in place first and check that the vent window doesn't hit it when opening.
As Craig said, mirrors for the passenger side are not such an easy thing to find. The aftermarket units don't match the 1980 style base so you'd have to use the 81-81 type base and they're very flimsy. I ended up using the head from an aftermarket one and mounting it on a factory base and stalk, mounted backwards.
Ron Luxmore
rlux2n2@gmail.com
fiat218
Re: side mirror
Post by fiat218 »
ga.spyder wrote:Jim..its like someone else typed it for you!! :lol: Just kidding.My82 doesnt have a pass. side mirror either.I have purchased or been given several mirrors off late models,and none are a match.I will find the right one eventually.
Haha I know, I don't have either one
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
azruss
Re: side mirror
Post by azruss »
Dont have a picture of the mirror, but i have everything else. this is a 80 FI
fiat218
Re: side mirror
Post by fiat218 »
rlux4 wrote:Are you talking about the driver's side? I've never heard of not having a mirror there. If that's the case someone has taken it off and welded the mounting holes I'm sure. You'd be able to see this by taking off the door panel and looking at the inside of the door skin, just aft of the vent window. Replacement mirrors for the driver's side are available, if you put one on just be sure to set it in place first and check that the vent window doesn't hit it when opening.
why would some one remove the mirror and go thru all the work of patching the hole then repainting that spot
easier to fix what was broke . so now what? i suppose i just need to go get 2 mirrors
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
azruss
Re: side mirror
Post by azruss »
I would, jim. I filled the hole and will transplant with an early style chrome mirror. part of my custom retro. my thought on the p.s. mirror. the early mirrors were so small that a ps mirror didnt give you much to look at. The inside mirror was wide and very close to the driver so it gave a large view angle that included the right side blind spot.
fiat218
Re: side mirror
Post by fiat218 »
azruss wrote:I would, jim. I filled the hole and will transplant with an early style chrome mirror. part of my custom retro. my thought on the p.s. mirror. the early mirrors were so small that a ps mirror didnt give you much to look at. The inside mirror was wide and very close to the driver so it gave a large view angle that included the right side blind spot.
i see:) i have a 69 style mirror, all new chrome
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Spiderbill
Re: side mirror
Post by Spiderbill »
Great thread,
I also want to replace the back mirror on my '80 2000 with a chrome one. Can any of the chrome ones be installed without body work that azruss is doing?
Bill
