Interior Back from Upholstery Shop
unplugged
Your car is a: 1981 Spider
Post by unplugged »
I went a bit darker than original tan interior which can be seen on the 2 door panels next to it.
For the center console I had them duplicate the stitched look from the Anniversary Edition model.
I am pumped to install it once it warms up a tad.
Dave
'81 Spider
Re: Interior Back from Upholstery Shop
it looks great!
divace73
Post by divace73 »
Nice work, how much does something like that set you back in the US?
Cheers David
see my >>You tube channel<<
Zippy
Your car is a: 1978 Fiat
Post by Zippy »
Looks great! I especially like the stitched console. It's going to make your car look like it was custom made. Have you decided what you are going to do with the door panels?
1978 Spider
unplugged
Post by unplugged »
I had the entire interior redone in the same color.
Front Seats, Rear Seats, Rear Qtr Panels, Door panels, Ctr Console, and matching boot.
The front seats had the foam redone and firmed up, the rear seats had rust that had to be stripped and coated and some padding redone.
The cost was around $3,500.
'81 Spider
divace73
Post by divace73 »
Hi Unplugged
Did you also have to repair your seat frames? Mine are buggered....
I am expecting around the AUD$4k mark as well.
Cheers David
Fiat88
Post by Fiat88 »
They did nice work! Like the color.
unplugged
Post by unplugged »
Fortunately the seat frames were in good shape.
'81 Spider
grittracing
Post by grittracing »
that looks great I like the stitching on the center console did you do the radio console the same?
baltobernie
Post by baltobernie »
Going to be a great looking car! What color exterior? Are you re-doing the dash, too?
unplugged
Post by unplugged »
Upper Console matches lower console.
Exterior is Blue
The seat in the picture is the original color.
I am planning on redoing the dash in Bird's Eye Maple. Inspired by Denise's dash. Engineered wood flooring from Home Depot makes a good base. Cuts clean and is stiffer then plywood. I used contact cement for my first attempt and it did not work out too well. I bought the veneer 6+ years ago so it was very dry and not very flat. The contact cement setup too fast to allow me to press it flat. Live and learn.
Album of restoration progress to date.
http://s771.photobucket.com/albums/xx35 ... storation/
'81 Spider
