Rougher with Header?
launieg
Post by launieg »
I just had Vick's header installed, along with rest of the rest of the exhaust system. So I've gone from stock '81 FI system to the header, 2.25 inch pipe and a matched muffler. Okay. I think I like the header - a little more hp maybe, and certainly the leaks in the old system are now gone, and the cat too, as well as the patched muffler. But it is now too loud for my liking, although a nice note. So I'm going back to the shop for a resonator to be inserted where the cat used to be. But, in the meantime, it now seems to have a slight tendency to miss when starting out in low gear - just brief and then fine. What could have changed? (It did get a new O2 sensor with the install.) Also, (without previous experience with a header) is it normal to have that "sort of backfire" sound at the muffler at times when I take the load off the engine? (I know I should know what that is, but I can't recall - yikes, gettin' old.) Do I now not have enough "back pressure", or is that a bs concept?
Launie
launieg
Re: Rougher with Header?
Post by launieg »
Just realized that I should check the timing. I bet they bumped the distributor a bit!
Launie
AndyVAS
Your car is a: 1980 Fiat 124 Spider
Post by AndyVAS »
These cars should run smoother with the header and full exhaust system. It all helps keep up velocity and increases scavenging between cylinders.
Andy Phillips
Vick Auto - Technician, Performance Engine Builder & PFI Developer (with ITBs)
http://www.vickauto.com
Stock parts or Performance parts we've got what you need.
launieg
Post by launieg »
Thanks Andy. Good to know. I am working on it, and also the muffler guy. I suspect we can see the proper results. I'll post when in a day or so, when it is fixed.
Launie
ORFORD2004
Post by ORFORD2004 »
Check your throttle position sensor. Need to be OFF(no contact) when gas is release.
