clutch cable
FordPrefect
Your car is a: 1977 Fiat Spider 124
clutch cable
Post by FordPrefect »
My clutch cable has a sort of washer which keeps it hooked on to the clutch pedal. The washer is worn down to barely anything, and the fork in which it fits in the pedal is a bit worn as well. The upshot is exciting moments on the road where I'm forced to learn how to shift without the clutch, and then find a safe place to fiddle around with it.
So, anyone have a solution? I don't think that washer thingie is designed to be removable, and if I could remove it, I have no idea what would make a good replacement.
Any ideas?
Re: clutch cable
you need to replace both the cable and the pedal.
FordPrefect
Re: clutch cable
Thanks. I did just order new ones from Vicks Auto. I guess I'll have to learn all about the process of replacing those things in the next week or so. In the meantime, maybe some wire will hold the cable just enough.
FordPrefect
Re: clutch cable
Another question: the rubber grommet thingie right where the clutch linkage enters the transmission crumbled out. How important is that bit?
Re: clutch cable
if you're referring to the boot around the clutch fork, it's pretty much a dust boot
FordPrefect
Re: clutch cable
Ok, I got a new pedal and cable installed, and stuck a dust boot on there, I'm not sure what's going on, but the adjusting nut is tightened all the way, but the clutch still isn't engaging. Kinda frustrating. Any ideas?
EDIT: It's possible the dust boot is on wrong, not sure that would matter though.
76was124
Patron 2019
Patron 2019
Re: clutch cable
Post by 76was124 »
Take a look at this post regarding pivot ball
http://www.fiatspider.com/f15/viewtopic ... hilit=Fork
Current 81 Spider 2000
Previous 76 Spider
FordPrefect
Re: clutch cable
76was124 wrote:Take a look at this post regarding pivot ball
Interesting, I'll have to take a look at the pivot ball. Tomorrow, maybe. I've been upside down too long.
FordPrefect
Re: clutch cable
Ok, that's definitely the problem, took the boot off, unhooked it all, and the lever/linkage thing just wobbles freely, doesn't work the clutch. How do I get it back on?
76was124
Patron 2019
Patron 2019
Re: clutch cable
Post by 76was124 »
If it wobbles up and down allot, meaning you hit metal to metal, you are correct.
The good news is you can fix it without taking the trans out, provided the pivot ball retaining spring metal isn't broken.
Remove the cable and clutch yoke return spring Sound like you already did)
Look at the pictures and you'll get the feel of how to position the yoke to nestle the pivot ball end of the yoke into position.
A good flashlight and a small dental mirror that is small enough to fit into the bell housing hole can help, but isn't mandatory.
Once you have it back on, re-attach the yoke return spring first. That helps keep it from falling off again when you re-attach the clutch cable.
Previous 76 Spider
ORFORD2004
Re: clutch cable
Post by ORFORD2004 »
Same thing happen to me yesterday. I try to use the dog leash to pull the cable and go back home but no way you can engage clutch that way. I ended with the clutch pedal in my hand and I built a bullet clutch pedal.
FordPrefect
Re: clutch cable
Well, I'm impressed. Got mine workin', btw. Thanks for all of your help!
76was124
Patron 2019
Patron 2019
Re: clutch cable
Post by 76was124 »
Glad to hear it.
For those keeping score.....+1 for the owners side.
Previous 76 Spider
ORFORD2004
Re: clutch cable
Not so fast... my brand new cable hold 5 days... The hook has to be able to twist in the pedal bracket. And mine doesn't
so I broke the cable right at the end of the fitting where the cable start. :roll:
But I have another idea with a steel angle. Pictures to come.
ORFORD2004
Re: clutch cable
bullet clutch strike 2
