Brake hose removal tricks?
CharlieB
Your car is a: 1976 Fiat Spider
Post by CharlieB »
Does anybody have any tips/tricks for removing a very stubborn brake hose from the brake line fitting?
I've tried PB Blaster to no avail.
1976 Fiat 124 Spider
lglade
Re: Brake hose removal tricks?
Post by lglade »
Vise Grip make a mini pliers (with a head designed to really support a hex nut) that works like a charm. Midwest Bayless has one in the tools section of their website.
You can also try a plumbers torch for about ten or fifteen seconds.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
124JOE
Post by 124JOE »
yes i pull the clip and push it up just enuf to grab with vicegrips
then one more pair of vicegrips on the line nut
but dont just turn it off make sure you arent twisting the line"it will break"
if the nut wont spin on the line then remove the rubber hose and spin it instead
bobplyler
Post by bobplyler »
+1 on the vise grips.
http://www.amazon.com/gp/product/B00004SBB8
The 7LW works great.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
ORFORD2004
Post by ORFORD2004 »
Go easy with the torch or you will have a loud surprise...
DieselSpider
Post by DieselSpider »
I can vouch for this particular model. I have a set of 2. The mini bolt/rod cutting jaws can come in very handy too:
Those and an old fashioned pair of fence pliers come in very handy. Modern version of the tool that won the West:
CharlieB
Post by CharlieB »
Sounds like those Vise Grips are the trick. I'll get a pair or 2.
Thanks for the input guys.
bobplyler
Post by bobplyler »
I just checked in the garage. Mine is the 4LW.
http://www.amazon.com/Vise-Grip-Adjusta ... B0076ITU64
lglade
Post by lglade »
One of each pliers would be ideal since the hex nut of the flex hose is bigger than the inverted nut of the brake line.
2015 Subaru Outback
2017 Ford Focus RS
DieselSpider
I have a set of the 7's and yes the 4 would probably be better for the smaller fittings.
Boris61
Post by Boris61 »
So did I buy flare nut wrenches for nothing? Should I get the vice grip tool instead?
lglade
Post by lglade »
Flare (aka line) wrenches are great until you get a nut that's really stuck. Then the flare wrench can sometimes flex just enough to let the nut spin inside, rounding off the corners. The vise grip can hold it all just a little tighter, which can make the difference between success and failure. I'd prefer to use the flare wrench whenever possible, but the vise grips are available when I have a nut that just doesn't want to come loose.
2015 Subaru Outback
2017 Ford Focus RS
DieselSpider
Boris61 wrote:So did I buy flare nut wrenches for nothing? Should I get the vice grip tool instead?
There are different quality flare nut wrenches with some being so springy that you sometimes need to use a pair of Vise Grips to keep them from spreading and messing up a stubborn flare nut.
A high quality set of flare nut wrenches in both metric and standard are a good addition to any tool box and are not for nothing.
narfire
Post by narfire »
I used flare nut wrenches in the past but I had a friend tell me to try and tighten just a tad before undoing. Perhaps the threads break enough to make it easier to undo.
aevansgatech
Post by aevansgatech »
Worst case, you can cut the hard line. I had a really stubborn fitting, tried PB Blaster, flare nut wrench, some heat. Nothing worked.
I was overhauling the whole brakes anyways (lines, rotors, pads, caliper seals) so I just cut it and made a new hard line
1979 Spider 2000 (gone)
