Proper torque for the temp sending units? Nothing in the manuals that I can find.
What is best common practice?
Second question: Sealant used at the coolant housing at top front of the engine? Not the one that holds the sensor, but the large one that bolts down onto the head directly, the "water extension housing", mounted with 4 bolts. It has a gasket. Should this be assembled dry or with sealant?
Thanks!
Pete
