With winter closing in up here in Cheeseland, I took last Saturday to finish installing the new H4 bulbs with city lights in the Blue 72. I'd finished the new 95amp alternator last week, so I was all set for connecting all the wires. Using the Greg Smith relay kit (get one!) and lights from A/R, I drilled small holes for the city bulb wires in the headlamp buckets. Installed a rubber grommet over the wires, tied a loose overhand strain knot on the inside, and connected the city bulbs to the front side markers. I wanted this to be easily reversible, so I assembled "V" connectors for each positive and ground lead, branching from the original marker leads to the marker lights and the city bulbs. Reconnected the battery, flipped the light switch to middle position, and:
I'm quite pleased with the results! Switched the ignition on, flipped the switch to headlamps, and wow....those are bright!!! Couldn't get the camera to take a decent picture, they were so bright.
Finished prepping the car for its winter nap, and completed all of the yard machine maintenance so there's space for the Fiat in the back garage.Goes in for the nap Wed night, ahead of the next drencher rain (while thelawn is still fairly firm). Snooze till April.....
Realized that I had no more parts sitting on the shelf, awaiting installation. First time in 3 years. THAT feels strange........
Neil
