Just as a bit of background:
I own a 1981 FI Spider and recently had a bit of a disaster. My double relay caught on fire on the fuel injector side and melted not only that half of the double relay, but also a lot of wiring. I got home from work and the car had been sitting for a few hours when the neighbors ran up and let me know my car was on fire
I have the double relay re-wired, and am fairly certain that each wire is where they should be going. I marked the wires before cutting and am currently using a multi-meter to double check everything. However, after wiring everything back up into the double relay, I can't get the car to start. I have no click coming out of the starter, even though it has 12 volts at it's connection on the starter, and on the red and black and wire on the double relay.
I have been following a list of diagnostics which I found here...http://www.angelfire.com/wa2/fits/index.html#ljetguide, but am running into troubles. Mainly, when I hook up my test light between 86a and 85, I get 12v across with the key in the "on" position, but lose the 12v in the "start" position, which is opposite. Also, when hooking up terminals 88z and 85 with the test light, I don't get 12v across, but connecting 88z to ground gives me the 12v across. Same thing with the pink and black wire, (terminal 86c I believe). So I hooked up my test light to terminal 85 and ground, to see if it was getting 12v, and the light did not come on. So somehow power is getting re-directed through the double relay in a way in which it shouldn't. I know I need to triple check the wiring at the double relay but if anyone had any other suggestions that would be awesome.
Sorry for the long post, I just wanted to be as detailed as possible, thanks for the help.
