Tranny noise
wqqdster
Tranny noise
Post by wqqdster »
Hi!
The trans in my wife's 93K mile '78 (she bought it new) has gradually been making more noise. In neutral it sounds like a bad bearing, first gear is very noisy (whining), second is pretty quiet, third is noisy, fourth is silent and fifth is a little quieter than first and third. There isn't any vibration coming through the shifter.
Anybody want to take a guess as to which bearing(s) are bad?
Gary O
redcars
Re: Tranny noise
Post by redcars »
You probably have bad bearing on the counter shaft, but until it is taken apart and inspected you are just guessing.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
4uall
Re: Tranny noise
Post by 4uall »
"Sorry, I'll try to make less noise" :wink:
Nanonevol
Re: Tranny noise
Post by Nanonevol »
Oh my God, Jay, you are hysterical! Keep it coming, as if you could stop!
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
4uall
Re: Tranny noise
Post by 4uall »
wqqdster
Re: Tranny noise
Post by wqqdster »
Obviously, I need to choose my words more carefully. Thanks for the guidance.
Gary O
Online
ORFORD2004
Re: Tranny noise
Post by ORFORD2004 »
Why don't you change them all? With the synchro, the springs and the forks. Then you are shure that you are good for long time.
http://www.ebay.com/itm/Fiat-124-Coupe- ... a7&vxp=mtr
wqqdster
Re: Tranny noise
Post by wqqdster »
That's the most obvious solution.... thanks for the link.
wqqdster
Re: Tranny noise
Post by wqqdster »
I got the trans out and spent some time with my stethoscope (sp?) spinning the shafts. The input shaft bearing had some play and was the easiest to get to so that's the one I changed. Took some fancy gear puller fabricating. The three piece bearing was replaced with a one piece.
I got everything back together and the bearing noise in neutral is gone!! Bazinga!! I'll have it back on the road this week and look forward to seeing if the rest of the gear noise it gone also.
Thanks for the help and the laughs!
Online
ORFORD2004
Re: Tranny noise
It's normal to have no noise on neutral if you change the input shaft bearing. But I don't think it will change anything on gears.
wqqdster
Re: Tranny noise
Post by wqqdster »
The noise in neutral was so loud I was assuming that it may also be causing noise when in gear. "Gear" noise probably wasn't the best term to use.....
wqqdster
Re: Tranny noise
Post by wqqdster »
I finally got all of my other chores done and was able to finish the work on our Spider. The transmission is silent now when driving with a very faint whine in third gear but I have to work to hear it. Just a couple more things to fix and it'll be back to being a real car again.
Gary O
