But confronted with this right off the bat:
So,...with the crimp connectors replaced with insulated spade connectors, and a new ignition switch, I find that number one fuse, "A" is energized with the key in the off position and I've had to remove my electric fuel pump from that circuit,...new switch because rebuilding and cleaning the old switch gave me this odd symptom first (after replacing the crimp connectors).
I doubt that this is a normal situation (especially since my electric fuel pump ran on that circuit for years, turning off with the key), and I'll simply install a toggle switch to control voltage to the pump, but I'm at my wit's end to come up with a reason why replacing the crimp connectors would cause this change,...big pink and little pink together, blue and blue/red together, and the rest are very straightforward.
I've only just started the car for a moment, since I have the fuel pump disconnected, but it starts/runs fine.
Suggestions as to why this is happening, how to fix it, and where I can attach my fuel pump (controlled by the ignition switch) in the meantime, would be greatly appreciated.
Todd.
