Hi,
since a few days , i'm trying to figure out how the tachometer is correctly connected.
where does the tachometer get his pulse, from the ignition coil, distributor,.... ?
can someone help me out?
Thx
Luc
Tachometer
- Your car is a: Fiat Spider Pininfarina 1979
Re: Tachometer
From the coil
Re: Tachometer
thanks,
since it's wired to the coil, probably the tachometer is dead....
any idea how to test it before a buy a new one?
Luc
Luc
Re: Tachometer
Check for power at the tachometer and continuity for the wire that goes to the negative side of the coil.
If everything is OK it's dead.
And I have a good one if you need it.
Re: Tachometer
I had a tach issue that was non responding 90% of the time. It took until the following year to discover that a loose ground cable on the battery terminal was the culprit.
Re: Tachometer
I'll check the wiring next weekend...
Thanks for your resoponses,
Luc
Luc
