Replacement Radio For a 1969 124 Spider
- SeldomSeen
- Your car is a: 2018 Fiat 124 Spider
The radio in my spider doesn't work. It's an aftermarket cassette radio with knob shafts that are 5 7/8" apart. It was installed by a previous owner. I would like to replace it with a simple, inexpensive radio with an AUX connector and the old style shaft mountings. Looking around, it seems that most of the new stuff has a different mounting systems but I don't want to modify the opening in my console. Any recommendations? I have a RetroSound system in my '72 Alfa GTV but it was $185 which is more than I want to spend. Besides, the clock is inaccurate.
It's never too late to have a happy childhood - Tom Robbins
1972 Alfa Romeo GTV 2000
1966 MGB Roadster
2007 MINI Cooper S
2018 Fiat 124 Spider Classica
1966 MGB Roadster
2007 MINI Cooper S
- seabeelt
- Patron 2019
Re: Replacement Radio For a 1969 124 Spider
Try cruthfield or classic car stereos, or vintage car radios.... Something like that in google. My son got one for his car. Looks the same when off, but is digital when turned on. Has different color displays to choose from, but I think it was a couple hundred bucks.
R/
R/
- SeldomSeen
Thanks. I'm sure something will turn up. I really only need the unit so that I can plug in my MP3 player. Radio is only satisfying if you like commercials which I don't.
1966 MGB Roadster
2007 MINI Cooper S
1966 MGB Roadster
2007 MINI Cooper S
- bradartigue
Search around for 1970's Blaupunkts that were knob-and-button but have an aux input. The aux was designed for adding an 8-track or cassette tape. There are instructions for making your own input to the thing.SeldomSeen wrote:Thanks. I'm sure something will turn up. I really only need the unit so that I can plug in my MP3 player. Radio is only satisfying if you like commercials which I don't.
1970 124 Spider
http://www.artigue.com/fiat
- Your car is a: Spider 2000 1982
bradartigue wrote:Search around for 1970's Blaupunkts that were knob-and-button but have an aux input. The aux was designed for adding an 8-track or cassette tape. There are instructions for making your own input to the thing.SeldomSeen wrote:Thanks. I'm sure something will turn up. I really only need the unit so that I can plug in my MP3 player. Radio is only satisfying if you like commercials which I don't.
Blaupunkt Köln and Frankfurt (old ones) might be suitable for you.
Spider 2000, 1982
Ex Jaguar X-type 2.2, 2009
Jaguar XE 2.0 AWD
"A single fact can spoil a good argument"
Jaguar XE 2.0 AWD
I would consider purchasing a radio with blue tooth feature as well as the aux jack. That way the music stored and the phone can be used with no hard wired connection. May not seem important right now but a few years from now MP3 type players might only be available with blue tooth.
I think most new radios come with new dress panels so any mods you make will be neatly covered and not show.
I plan to install a blue tooth amp that is hidden. it is operated from my i phone. So I will have no antenna or radio display. SoFlaFiat has a photo of one he mounted in his build under "Restoration Projects". No sure what I will use the unused panel space for.
- bradartigue
Put a correct-for-your-year radio in there and rig it so it lights up w/o powering the speakers.spider2081 wrote:I plan to install a blue tooth amp that is hidden. it is operated from my i phone. So I will have no antenna or radio display. SoFlaFiat has a photo of one he mounted in his build under "Restoration Projects". No sure what I will use the unused panel space for.
1970 124 Spider
