Decided to immortalize the in progress build of my second spider, a 1980 carbed model. Nothing has been untouched. The car was originally metallic brown, poorly painted a bluish green, and then stripped down by me and my dad, bare metal, then painted a 3 stage Ferrari red used by F1 cars. Believe it was the 07' color. I'm generally bad at these but I'll keep it updated. First few posts will be playing catch up. The car will be using the trans that came with it, along with the engine from my '76 that I built with cams, 8mm domed pistons and a balanced assembly. My signature is wiring, so nothing will be left untouched. However, my plan is to have nearly every modification to be reversible, even though I never plan to do so. As such, almost no wiring will be cut, instead opting to plug into the stock wiring and making modifications after the plugs when possible. Most of the wiring is in the trunk however, where the alarm brain, relays, trunk solenoid, amplifier etc. sit. This allowed me to simply source my required inputs and bring them to the trunk where relays keep all the load off of the ignition switch and primary wiring. Anyway, first post. First few will be very brief and show ridiculous progress. I'm just too lazy to post all my progress up to now in one night. They're just a few shots before I started really documenting it. My dad is a member here too, and may supply some shots as well.
As you can see, front holes were welded up. No bumpers on this car. Turn signal solution will be shown later. Front suspension with prima 3 tubular a-arms and yellow koni shocks. Will update more later.
