Here are the wires.
Here is the bottom of the old switch.
Here is the bottom of the new switch.
What colour wire goes on which connector number and what are they for.
00.3? You should be reading from the + post to ground (any good bolt / chassis point) and it should be battery voltage, north of 12 volts.Funcar wrote:Yes. I bought a smart multiple meter. When I touched the wires on top of the coil it beeped. Reading 00.3.
I appreciate your help. What is the next step? I know you will probrably think at least subconsciously this guy needs to take it to a mechanic.![]()
I do enjoy learning anf working on this car
