Another issue i am having is fuse 10 continues to blow. I am in the process of isolating the problem. The out appears to be the voltage regulator and the in's appear to be the fan switches. I disconnected the fan switch relay and its still blowing. Maybe its my VR kicking power back?
Lastly, every so second or third startup my ignition coil continues to receive power with the key out.
Any thoughts? And i thought body work was tough!
