I tried doing a search on this but nothing came up that would help. When i go to start the car as long as the warning lights come on the car will start. If the warning lights don't come on the car will crank but not start. I doesn't do it all the time, its just frustrating when it does. I have to turn the key off an on until the warning lights come on. Warning light's (brake and fasten seat belt dash lights). Any help would be great.
Ozzie
79 won't start unless warning lights are on.
Re: 79 won't start unless warning lights are on.
Does the clock also stop running when the warning lights don't work? I had an intermittent problem like this and it turned out to be the feed from the alternator to fuse 10 on the hot side. The warning lights come off this circuit as does the clock AND the supply to fule pump relay.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
I'm not sure. I will have to go check.
Thanks Ozzie
Thanks Ozzie
Well I checked and the clock keeps running. I drove around a bunch yesterday and it didn't do it once. Its acting like a relay of some kind.
Ozzie
Ozzie
I had the exact same problem with my '82 and it was the ign switch.
Trey
Were you able to fix it, or did you have to replace the ignition.
Ozzie
Ozzie
You can try repairing it, nothing to lose! See This link. http://www.mirafiori.com/faq/content/switch/index.html
1989 Spider, sold
2008 Mercedes SL65
1989 Spider, sold
2008 Mercedes SL65
Thanks for all the replies. I will try to rebuild it. It can't be to hard I already rebuilt the hazard switch and the window washer pump.
Ozzie
Ozzie
New member here.
Recently purchased a 1978 Spider 124.
I have the exact same problem. I will be following this thread closely Ozzie. Also, I will be tackling this same problem this coming weekend. I'll let you know my findings. I'm surprised no one else has experienced this electrical gremlin and found a solution as yet.
Good luck Ozzie!
Good luck Ozzie!
Sorry to revive a 4 year old thread, but I am having the exact same issue that has gotten worse over the past few weeks. Do we have any confirmation that it is juts a bad connection, or do I need a whole new switch.
Thanks!
Thanks!
