Unused Alternator Wire
- gcorsar
- Your car is a: 1975 Spider
While checking the back of my alternator I noticed a gray wire that wasn't connected to anything. There were the heavy black wires, a yellow/red wire, and a condenser wire, but no extra terminal that might be where the gray wire goes. After searching, I found that the gray wire is supposed to go to the voltage regulator. Wow! How is this thing running with that not connected? Or is there a newer version of the alternator that has a built-in regulator making the gray wire obsolete? Any ideas?
1975 Spider (just for fun)
2000 Dodge Caravan (only because I have to)
2012 Toyota Camry XLE (reliable commuter)
Re: Unused Alternator Wire
Yes, newer cars have the alternator with a built in regulator.gcorsar wrote: Or is there a newer version of the alternator that has a built-in regulator making the gray wire obsolete? Any ideas?
What he said. The gray wire used to go to the voltage regulator. If you want to be sure, post a pic of the back of the alternator and we can tell you if it's the newer type with the built-in voltage regulator.
- gcorsar
Well, I *think* the box that is barely in the pic on the right is the voltage regulator. The rest of it looks like an internally
regulated alternator too, so I think you are safe.
