Using a 1/2 in ratchet, I have the puller as tight as I can go, and still not a bit of budge from the steering wheel (though I have not yet found/tried a cheater). I even was desperate enough to cover the puller's hex end with a socket extension bar, and gave it a few good raps with the ball peen hammer. Nut's there to keep the whole thing from ventilating the garage door.....
Any ideas on what next? I need the wheel out of the way so I can pull the dash and prep the rest of the interior (and hopefully install a new dash this summer). I read about dropping the column, but I have those "round head" bolts and no room to Dremel a slot in the head or grab with a vise grips.
Thanks.....
Neil
