Sorry if this has been asked already, but it is not clear to me.
I know the jacking point just ahead the rear wheel.
I know it is also the right place to place a stand when the car is lifted by a jack.
But if I want to use this place with a stand, where do I put the jack, to lift the rear wheel ?
I want to bleed the brakes and I need available and safe space under the car to do it.
I know the answer fot the front.
thank you in advance.
Jean
jack and stands points
Re: jack and stands points
here is how I jack the rear
my understanding is that when you bleed the rear brakes the axle needs to have weight on it so you can place your jack stands on the axle
this is what the jacking points look like
How about the front? Especially if you've installed the oil pan protector?
- kilrwail
A low-profile aluminum floor jack will roll under the oil pan and allow you to jack the crossmember in the centre, right behind the oil pan.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
low profiles are awesome
Yes! Key words are low profile. If you shop at Harbor Freight, they make a variety of jacks, and fortunately they list the dimensions on the outside of the box. There is a 3-ton for I think about 70 bucks (?) that I bought 2 years ago that just gets under there and does a great job, but you still have to come in at it a little from the side if you have a spoiler installed.
- focodave
I bring mine in from the side, at an angle, with the floor jack just behind the left front wheel/tire.
I lift using the front cross-member.
That gives me room to crawl under the front of the car with no jack in the way.
1970 MGB GT (my other hobby)
Yep, same here. Put the jack stands in for safety though, NO CINDER BLOCKS! Had a scare as a foolish youth with those stupid blocks.
as extra safety I always recommend putting the tires/rims under as well
and always let someone know what you are doing
RRoller123 wrote:Yep, same here. Put the jack stands in for safety though, NO CINDER BLOCKS! Had a scare as a foolish youth with those stupid blocks.
well, the partner who will press the pedal...4uall wrote:as extra safety I always recommend putting the tires/rims under as welland always let someone know what you are doing
- Your car is a: 1970 Spider
Just a point of clarification...
It is the brake regulator that necessitates that the rear axle be under load to bleed the rear brakes. Without weight on the rear wheels the regulator will not allow fluid to pass.
However, many have bypassed the regulator. If this is the case, the weight bearing requirement is no more.
Dushore, in Northeast PA
1970 124 Spider (red) and a 1979 2000 Spider (Ferrari yellow)
Also: a pair of 1952 MGTDs
1972 Fiat 850 Spider
1965 Chevelle SS Convertible
1975 Corvette
1986 Lada Niva
1975 Corvette
1986 Lada Niva
