77 Restore begins
- hallgreghall
- Your car is a: 1977 Fiat
Re: 77 Restore begins
Yes I am planning on pulling the engine. I am hoping to pull it in a couple of weeks.
I like Italian food and Italian convertibles
- hallgreghall
A little more progress. My boys think it looks more like a boat than a car at this point.
Make sure you Epoxy primer that metal then use some 2K high build primer on it.
- hallgreghall
We were back to working on the car today and found a piece that is not connected to anything. Does anyone know what this is and what it should be hooked up to?
It is in the trunk by the fuel tank.
- SLOSpider
Never saw anything like that. Wiring does not look factory. Is the antenna in that location? Some kind of noise suppressor?
- 124JOE
it might be for a power anttena
the power leed
one for up and one for down
the power leed
- hallgreghall
So we finally got back to working on the car a little this evening. We pulled the doors off and did a little more sanding.
. I made the mistake of removing the trunk lock linkage, the lock mechanism fell out and springs and small pieces went everywhere. Luckily I found all the pieces and will work on putting it back together later.
