Alternator pulley Resolved
ga.spyder
Post by ga.spyder »
Hey guys,does anyone have a illustration or a disassembled alternator pulley assembly?I was replacing my alternator,and removed the pulley assembly(all 27 freakin' pieces),and carefully taped them together in the exact order they came off.Of course,I picked them up to install on the new alternator and the tape hadnt held and they landed all over the garage floor.I didnt think I would ever find the woodruff key!!! :twisted: :twisted: Anyway,I tried to reassmble using my failing memory.After installation,it doesnt look like it is turning true.I may have to remove and wouild like to see if I have the proper sequence of washer ,spacers,fan blades,and pulley!!! Thanks
Craig
Craig Nelson
Fling It Around Turns !
4uall
Re: Alternator pulley !
Post by 4uall »
these may help
http://www.pirate4x4.com/tech/billavista/Wiring/Part2/
scroll down a little
ga.spyder
Post by ga.spyder »
Thanks Jay.It is a very informative site.I saved it for when I can actually read all of it.It doesnt help with the Spider pulley assembly though.Our(at least my 82)pulleys are 2 piece and there are several different size and shaped spacers and washers.The shaft has a woodruf key that hold them intact.I had them all in order,and when they dropped.... :( I am not sure if I have them right or not,but something looks odd.The belt is in line and its charging,but it lokks to be wobbling a bit.Not sure,
Craig
Craig Nelson
4uall
Post by 4uall »
:oops: :cry:
ga.spyder
Post by ga.spyder »
Hey Jay...it is a cool site! :D
I have a factory shop manual and it is no help at all!
Craig Nelson
BEEK
Your car is a: 1975 Spider
Post by BEEK »
if you send me a picture with all the parts , label them for identification,(a,b,c or 1,2,3) i can tell you in what order to place them
75 spider
son has 78 spider
lanciahf
Post by lanciahf »
ga.spyder
Post by ga.spyder »
Thanks Ralph.That is the same drawing I have.The pulley is a 2 piece with several spacers and washers.I thought I had them right but it is making some noise from the pulley area.I may go ahead and take it back out and reconfigure all the parts,to see if I can stumble onto the right combination!! :D I was so careful to take the components out in order,but the trip off the bench and onto the concrete.....
Craig Nelson
I don't have a diagram but have a couple alternators. What brand and part number is the one you have. If stock I think it should be a Bosch 65 amp.
ga.spyder
Post by ga.spyder »
I replaced my stock Bosch with a rebuilt(lifetime warranty!) from Autozone.It worked fine for a number of years.It was making some noise,although still charging.I took advantage of the warranty and got a new one.Then I dropped the whole pulley and spacer assembly on the floor! That is my stock pulley assly because the Zone units dont come with the pulley.
Craig Nelson
dmwhiteoak
Re: Alternator pulley Resolved
Post by dmwhiteoak »
Well Craig, how did you resolve this issue?
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
ga.spyder
Post by ga.spyder »
Dennis,I took the alt back out and experimented with differnt combos of spacers,and washers.I hit on one that seemed secure and spun freely.I went ahead and installed and all seems good.Belt lines up,no noise,and no wobbling.Is it right...I dunno but it works !! After I was done and took a ride I thought ''Hmmmm,I should have taken a pic of the sequence'' :oops: Too late now!!
Craig Nelson
dmwhiteoak
Glad you got it. I didn't have doubt.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
