Quick cold starts, run for about 30-45 minutes, shut down.....no restart. Gas smell with choke all the way *in*. Tried the "pedal to the metal" twice, and it worked (memories of the old 71 coupe!), but today at the body shop, no luck after 30 minutes of trying. While I cranked, the owner (a friend) held first the coil wire, then a plug wire, against a ground, and he reported no spark.
Details: 72 124, 1 year on engine rebuild by prior owner, 49.4K on the whole car. Electronic ignition system fitted, and coil looks very recent. White module on coil's side looks aged. All conections tight. Idles at spec and runs smooth on the road. Any trouble shooting suggestions or fixes?
At the shop for an estimate on the boggy driver pan. Owner says it's the only bad place on the car, and he's never seen one so old and so solid. New pan, labor, and a paint buff out/touchup for about a grand. I've seen his prior work....it's immaculate.
And, yeah, pix when I can whittle them down to the required size.....
