On a separate note last weekend I had a lot of smoke pouring from the ignition switch. i pulled over, shut down and it stopped. Sat for a few started right up and drove home with no further issue.
I did not check to see if anything was not working after that issue happened. So I dont know if I had lights BEFORE I started the relay job but I would guess that I did and that I made an error on the wiring. More likely a bad connection or something but why would the parking lights be on full time?
Thanks all
George
FORGOT TO ADD FUSES TO THE POWER DIST BLOCK... IT IS WORKING NOW
