I'm nearing the end of my rewire on the car. Right now, I'm just working-through the instrumentation. I've got a question about the water gauge.
In my wiring diagram (pictured below) it shows a "Heat Gauge additional resistor", labeled as #17, middle/left of photo.
So as I read the circuit, I've got power to one side of the gauge. the other side is that green wire, which goes direct to the temp gauge sending unit (labeled #18), and through that to ground. But jumpered into that wire is a resistor and then the temp "switch" (labeled #14) which pegs the gauge when it closes to ground.
So my question: what's that resistor? its specs and function?
