Weber 32/36 DFEV Upgrade: Game, but Ignorant
- opus10583
- Your car is a: 1978 CS1
Re: Weber 32/36 DFEV Upgrade: Game, but Ignorant
Thanks Matt, thanks Mark.
...Big dumb mistake on my part, I was worried about air filter housing clearance.
ANDIAMMO: 2012 500 ABARTH
- opus10583
Hi guys,
Before I go nuts and start overnighting spacers and gaskets from the four corners:
Are we sure?
IAP pairs the DFEV with the 12mm spacer in their catalog.
Mark
Are we sure?
Mark
- manoa matt
"Are we sure?"
Absolutly sure. I just had a 32/36 last week, compared it against a 32ADFA and installed them both on the same stock manifold with stock length manifold studs and took measurements.
1 1/8" spacer would be ideal with thin paper gaskets, 1 inch spacer would be good with the 1/8" thick fiber gasket that usually comes with a rebuild kit.
If you stack two 10mm spacers the stock length intake manifold studs will protrude above the carb base plate higher than usuall. If you look closely at the carb, three of the four studs will not be an issue, however there is a tight clearance height around one of the studs due to the choke housing or the accelrator pump housing. That one stud may need to be shortened.
- 124JOE
hey guys i was just in there today
i mesured 45mm to where i want the top of the carb mount
the base is 10mm thick
and the two gaskets are 1mm each
one for the top of spacer one for the bottom
is the 1 1/8 spacer 33mm?
- manoa matt
Joe, no one makes a 1 1/8" spacer. Closest is a 1 inch from Jason Miller at Millers Mule. I think a 1 inch spacer with gaskets on both sides would be close enough without issues.
What I used for a spacer was the throttle plate from my original ADHA. I tapped the holes that the trottle plate shafts went through, and put bolts there. I sealed them with both epoxy and loctite. I sealed any other holes with epoxy. It's worked great for over 10 years. But I'm wary of the epoxy. I'm getting ready to replace it with two spacers.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
- 124JOE
matt i sent him a PM last week and heard nothing back
- 124JOE
ok so i went to his site
1/2" thick spacer 25
1 " thick 30 bucks
1 " thick 30 bucks
I've also used the base plate from the adha carbs. One advantage is that you gain some vacuum ports which can be handy when reconnecting the emission equipment
- 124JOE
but i dont want to wreck the adfa
- boogiedude
- Your car is a: 1978 spider 1800
the adfa and adha are different. 32adfa and 28/32 adha
the adha is the weak anemic carb used on the 79 and 80 carb'd cars
- 124JOE
yes and the holes are smaller
so if i use a base off the adfa
it will be the same as the adfa
responce wise
responce wise
- opus10583
Hi,
Thank you all for the guidance.
I've been persuaded the path to personal enlightenment lies through shorter mounting studs.
...Look for my next thread, "How the hell do I remove these %#^$*_&?"@¿8+! carb mounting studs?" sometime Saturday afternoon.
Mark
Mark
- 124JOE
the taller spacer give you more low end tourqe
- opus10583
Hi Joe,124JOE wrote:the taller spacer give you more low end tourqe
I have heard and considered that, I don't see it being a controlling quality; 4-2-1 added torque, free-er breathing carb and filter will add torque, don't consider another 12mm of plenum to be significant.
Mark
