These two white/black wires connect to a brown wire and come out from under the center console. No idea where this goes. The emergency brake light works. I am not sure of the backup lights as the PO TOOK THEM OUT!!!!! So I am not sure if this is for them. What is this?????
This light blue/black wire is riveted to the back of the dash behind where the emergency brake light is located. I have no stinking idea about this one. Any ideas?
This is another good one. These red and brown wires are by the fresh air vent on the driver's side. I have not dug into the fuse panel to see exactly where these come from. All I know is that is not up to Fiat standards no matter what anyone says! (ha ha) Any clues?
Also, my heater fan did not work as the black wire (ground) was not connected to anything. Where should it go?
I have more pictures and questions and will update this when I can get them here.
Thanks for the help in advance.
